I have to add some additional item in the MdiTabContextMenu , so i override the OnInitializeContextMenu to do it.
But the Items i've added appears in the end of the list , even if i set up their index property , it seems that it does not work at all.
Is there any other property that i've to configure to get my MenuItem in the rigth Index ?
Hello ,
I have handled InitializeContextMenu event of the UltraTabbedMdiManger and I was added there following code line :e.ContextMenu.MenuItems.Add(1, new MenuItem("Test Item"));And this insert a “Test Item” on the desired position.
Let me know if you have any further questions.
