65
Adding property to UltraWinGrid Cell
I have a wins form project and am using an UltraDataSource
where I add rows to the data source programatically.
The user enters values into the cells of the grid manually, and then presses a save button,
which then goes and carries out an action on another system by uploading a file to said system.
The application when queries the other system to get a results file.
The application will then process the results file, displaying a message to the user of an exceptions.
What I would like to do is add 2 properties to each of the data input cells, 1, which would hold the exception
message, and 2 would hold a 'Saved' state.
If the Saved state was true, the background colour would change to green, else it would change to red...
Is it possible to 'inherit' a new cell class and use it in the grid?
