775
How to bind the "Font.Strikeout" property
I would like to bind the "Font.Strikeout" property on one control based on the value in another control. For example, I have a column called "Setup Time" that I display in a form using an UltraNumericEditor control. I want the Setup Time control to have the strikeout applied when the value in another column called "Production Reported" is set to Yes.  The following is the code I am trying to use but it is not working. Can you help me figure out the best way to do this?
if (fieldName == Constants.WorkOrderSetupTimeFieldName)
aControl.DataBindings.Add(new System.Windows.Forms.Binding("Font.Strikeout",_dataSource, Constants.WorkOrderIsProductionReportedFieldName, true, DataSourceUpdateMode.OnValidation));
With this particular code I get an arugment exception error saying that I cannot bind to the Strikeout property on the Setup Time control ...
Steve
