I get the following error in the upgrade log when i try to upgrade a Visual studio project.
12:06:19: web.config has been backed up.
12:06:19: Updating LatonClient.csproj...
12:06:19: LatonClient.csproj has been backed up.
12:06:19: No matching assembly located in available assemblies Infragistics2.Win.UltraWinCalcManager.v10.1.FormulaBuilder
12:06:19: at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyList.AssemblyNameChange(String assemblyName, Int32 versionLocation, XmlNamespaceManager xmlNamespaceManager, String& assemblyNameNoVersion, Boolean ignoreErrors)
at Infragistics.VersionUtilitySupport.Core.ProductAssemblies.AssemblyList.FindNewAssemblyNode(String assemblyName)
at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.FetchNewAssemblyNode(String assemblyOldName)
at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
Hello, I have a similar problem with Visual Studio when I try to upgrade either the solution or the project files. I only use Windows Forms (I don't use Silverlight neither ASP). I get this in the upgrade log:
04:56:56: Running User Interface Version 12.2.20122.100004:56:56: Gathering volume and assembly information.04:56:56: Gathering volume and assembly information.04:56:56: Could not locate registry entry Software\Microsoft\Microsoft SDKs\Silverlight\v5.0\AssemblyFoldersEx where we look for installed products.04:56:57: Referencia a objeto no establecida como instancia de un objeto.04:56:57: en Infragistics.VersionUtilitySupport.Core.Product.IGProductManager.FindInstalledProductsUsingRegistry(String volumeToUpgradeTo, String clrToUpgradeTo)04:56:57: Could not locate registry entry Software\Microsoft\Microsoft SDKs\Silverlight\v5.0\AssemblyFoldersEx where we look for installed products.04:56:57: Referencia a objeto no establecida como instancia de un objeto.04:56:57: en Infragistics.VersionUtilitySupport.Core.Product.IGProductManager.FindInstalledProductsUsingRegistry(String volumeToUpgradeTo, String clrToUpgradeTo)04:57:37: Analyzing OrtsTorres.vbproj...04:57:37: The project has references that need to be updated.04:57:37: The project has publishfile entries that need to be updated.04:57:42: Updating OrtsTorres.vbproj...04:57:42: C:\ORTS TORRES\OrtsTorres\OrtsTorres\OrtsTorres.vbproj has been backed up.04:57:42: Updating Infragistics2.Win.Misc.v10.1 Version=10.1.20101.1007 to new reference Infragistics4.Win.Misc.v12.2. Version 12.2.20122.100604:57:42: Updating Infragistics2.Win.UltraWinEditors.v10.1 Version=10.1.20101.1007 to new reference Infragistics4.Win.UltraWinEditors.v12.2. Version 12.2.20122.100604:57:42: Updating Infragistics2.Shared.v10.1 Version=10.1.20101.1007 to new reference Infragistics4.Shared.v12.2. Version 12.2.20122.100604:57:42: No matching assembly located in available assemblies Infragistics2.Win.UltraChart.v10.1.Design04:57:42: en Infragistics.VersionUtilitySupport.Core.Product.AssemblyXmlFile.LocateNewAssembliesNodeforCurrentAssembly(String assemblyName) en Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
Thank you :)
no, as there are historical builds of the application at a point in time...
Do you want the Version Upgrade Utility to upgrade the web.config files in the Builds folder that reference our assemblies?
I have logged this as an issue with our development team.
Because of the way the Version Upgrade Utility is designed, your best solution is to move the "Builds" folder out of the solution folder when you upgrade the project. The utility looks through the folder tree for any web.config files and that's what's causing the issue.
