140
How to prevent node from being active on loading the form?
I am using Infragistic UltraTree in windows aplication. I am populating the tree at runtime. I have set some overrides for the tree like the active node should be bold.
Problem:
When the form is shown, my first node is in bold.
What i want: i dont wnat the first node to be bold .i.e i dont want it to be active, the moment form is shown. The node should be active only when the user clicks on the tree node.
Help
Thanks & Regards
Casey
  • 4618
    Hi Casey,
    I came across this thread and noticed that no one has offered an official solution for this issue. I have created a general guide for producing the effects that you have described; please use the provided link to view that thread.
    http://community.infragistics.com/forums/t/67221.aspx
    If you have any further questions regarding this inquiry or the solution, please let me know.
    Sincerely,
    Chris K
    Developer Support Engineer
    Infragistics, Inc.
    www.infragistics.com/support
  • 765
    I do the same thing.  What about making the node bold for the selected nodes appearance rather than the active node?  The selected node you can turn on or off manually and a node is selected when the user clicks the node.  I'm not sure about turning active nodes on or off.
