165
UltraNumericEditor shows incorrect value when loosing focus
using NetAdvantage for WinForms v. 10.1 I'm facing the following issue:
UltraNumericEditor is docked into a cell of a tableLayout. Default properties changed in design-time as following:
.Nullable = true
.Value = null
.PromptChar = ' '
In runtime, after  value is edited and control lost focus, null's('0') are truncated from the right side of the shown value. But the .Value property  still has a correct value.
Why is this truncation happening? What I'm doing wrong?.
Thanks!
  • 69832
    Verified Answer
    Insignificant digits (i.e., trailing zeroes) are not displayed by default when a decimal/float/single value is displayed. The control exposes a Format property, so you can assign a value like (for example) "#.0000" to that property to force a certain number of decimal places.
