95
Shared Control - UltraTabControl
Problem fixed, please ignore. Description below.
Hi All,
I'm dynamically adding 2 shared controls to a UltraTabControl, one as a header and one as a footer. There are 7 tabs on the control. The problem being that the shared controls are diaplaying on 6 of the 7 tab pages only. they do not appear on the first tab page in the UltraTabControl. Has anyone came across this problem before and any solution out there?
Redrag
Never Mind, problem fixed, Each tab page had a table layout control on it with dock set to fill. The first tab had no dock setting so the table layout was drawing over the header and footer shared controls. (School boy error).
  • 48586
    Hello ,
    I am glad to hear that you were able to solve your issue.
