I have an application where the user has the ability to save multiple layouts. By default I save a single default layout in the DB. The first time the user logs in, the default layout is used. However this causes a delay in loading.
Each grid in my application has what we call a RepNumber. The filterrow contains the column for repname, which is tied to the repnumber. What I would like to do is create a layout for each user when I save the default layout for the first time.
How can I take an existing layout and create a default that is catered to each specific user? Also, when ever a new user is added to the system, I would need to create the default layout records for that user.
My initial thoughts where to have the db triggers perform these function, but I dont know how to add filters to an existing layout.
By the way I am serializing the layouts with XML...
Matt,
I have opened a case if you need more detail. It includes an explanation and sample code.
The case is CAS-49666-Q37X30
My requirements require this to be a little more dynamic. As I said before the event that would trigger this is the insert of the default layout record into the DB. This would be rather easy, however this is a product that we sell, thousands of companies and even more users.
That being said, what I really need is a way to TRIGGER off the insert of the initial default records into the DB. This record would be created during database migration or the insert of a new rep. From what I can tell I would need to clone this record for each REP, adding the additional filter into the XML of the default record and saving it into the REP specific table where I store the REPS filters.
My question then is how to interject a new filter criteria directly into the default filter XML?
HI,
Just following up on our forum thead.
I hope my sample resolved your issue regarding the multiple layouts with different filtering.
If you have additional questions regarding this issue, please let me know .
Sincerely,
Matt
Developer Support Engineer
HI Elfmanne,
I created a sample application that creates several different wingrid layouts, each with different filtering conditions. I then apply these layouts to several different grids.
Here is a code snippet to create the layouts with different filtering
UltraGridBand band = ultraGrid1.DisplayLayout.Bands[0]; band.ColumnFilters[0].FilterConditions.Add(FilterComparisionOperator.Equals, 2); ultraGrid1.DisplayLayout.SaveAsXml("Acct2.xml");
band.ColumnFilters[0].ClearFilterConditions(); band.ColumnFilters[0].FilterConditions.Add(FilterComparisionOperator.Equals, 3); ultraGrid1.DisplayLayout.SaveAsXml("Acct3.xml");
Here is a code snippet load the layouts
ultraGrid2.DisplayLayout.LoadFromXml("Acct2.xml"); ultraGrid3.DisplayLayout.LoadFromXml("Acct3.xml"); ultraGrid4.DisplayLayout.LoadFromXml("Acct4.xml"); ultraGrid5.DisplayLayout.LoadFromXml("Acct5.xml");
The sample project is too large to attach to this forum post. I will email it to you directly.
Please review my sample application. You will need to readd the Infragistics references to run this project.
