164
How I can add combobox in ultragrid columns header and select items from it?
Hello!
I have a little skills in Infragistics components and controls, and I have a problem...
I need add combobox at the ultragrid column header.
I do this:
1. I'm create new class, which implements IUIElementCreationFilter interface
public void AfterCreateChildElements(UIElement parent)
if (parent is HeaderUIElement)
HeaderBase aHeader = ((HeaderUIElement)parent).Header;
if (aHeader.Caption == "Money")
TextUIElement aTextUIElement;
                    EditorWithComboUIElement aComboBoxUIElement = (EditorWithComboUIElement)parent.GetDescendant(typeof(EditorWithComboUIElement));
                    UltraGridComboEditorOwner embeddableEditor = null;
                    EditorWithCombo editor = null;
                    UltraCombo combo = null;
                    if (aComboBoxUIElement == null)
                        combo = new UltraCombo();
                        embeddableEditor = new UltraGridComboEditorOwner(combo);
                        editor = new EditorWithCombo();
                        aComboBoxUIElement = new EditorWithComboUIElement(parent, embeddableEditor, editor, null, true, true, true, true);
                    else
                        combo = aComboBoxUIElement.Owner.GetControl(null) as UltraCombo;
                        embeddableEditor = aComboBoxUIElement.Owner as UltraGridComboEditorOwner;
                        editor = aComboBoxUIElement.Editor as EditorWithCombo;
                    combo.DataSource = _courses;
                    combo.DisplayMember = "VchCode";
                    combo.ValueMember = "Vcode";
                    combo.SelectedRow = combo.Rows[0];
aTextUIElement = (TextUIElement)parent.GetDescendant(typeof(TextUIElement));
                    if (aTextUIElement == null)
                        return;
                    ColumnHeader aColumnHeader =                     (ColumnHeader)aComboBoxUIElement.GetAncestor(typeof(HeaderUIElement)).GetContext(typeof(Infragistics.Win.UltraWinGrid.ColumnHeader));
                    aComboBoxUIElement.Editor.ValueChanged += new EventHandler(Editor_ValueChanged);
parent.ChildElements.Add(aComboBoxUIElement);
                    aComboBoxUIElement.Rect = new Rectangle(parent.Rect.X + 3, parent.Rect.Y + (parent.Rect.Height - aComboBoxUIElement.Owner.GetControl(null).Height) - 3, parent.Rect.Width - 6, aComboBoxUIElement.Owner.GetControl(null).Height);
                    aTextUIElement.Rect = new Rectangle(aTextUIElement.Rect.X, aTextUIElement.Rect.Y + 2, aTextUIElement.Rect.Width, 18);     // 18 - height of aTextUIElement.Rect... it's bad code...
                    // In this case, i dont't know how i can widen columns header, if it height less than sum                           // of aComboBoxUIElement and aTextUIElement height...
                    if (aHeader.Height <= aComboBoxUIElement.Rect.Height + aTextUIElement.Rect.Height)
                        aHeader.Band.ColHeaderLines = aHeader.Band.ColHeaderLines + 1;
else
                    EditorWithComboUIElement aCheckBoxUIElement = (EditorWithComboUIElement)parent.GetDescendant(typeof(EditorWithComboUIElement));
if(aCheckBoxUIElement != null)
parent.ChildElements.Remove(aCheckBoxUIElement);
aCheckBoxUIElement.Dispose();
        public bool BeforeCreateChildElements(UIElement parent)
            return false;
In result execution this code, combobox is created, but i can't select items from combobox.
Combobox in header has items, but it behaviour like readonly
P.S.: Sorry for my poor English...
