I have ultara grid have all column CellActivation's property is set to false in order to disable all grid column except column[9] that have value list ,i have either column[10] with value list but it is CellActivation's property is set to false
i want to set column[10] CellActivation's property to true when change value of column[9] withen the same row not for entire grid
Use InitializeRow event:
if (e.Cell.Row.GetCellValue(column9Key) == myValue)
e.Cell.Row.Cells[column10Key].IgnoreRowColActivation = true
e.Cell.Row.Cells[column10Key].Activation = Activation.AllowEdit;
else
e.Cell.Row.Cells[column10Key].IgnoreRowColActivation = false
