560
Out of Memory & Standard Palette
I am using version 9.1. I am having memory issues as I am trying to write 12-25 worksheets into single workbook.
1) Is there a way to append single spreadsheet to existing excel document on disk each time without loading complete workbook into memory.
2) Using standard palatte I am able to write more worksheets. Is there a way to set standard palatte after loading existing workbook using workbook.load
(related discussion) http://forums.infragistics.com/forums/t/39942.aspx
please advice
Thx
  • 469350
    What version of the assemblies are you using? I thought we had already made some changes to the Excel assembly so that is uses temp files and avoids these sorts of problems, but maybe I am wrong.
    I do not beleive there is any way to do this currently.
    I don't think there's any way to do this, either. The palette mode has to be set when the Workbook is created, you can't change it later.
