1176
drag and drop into a wingrid
i did something similar between a explorer bar items and a ultramonthviewsingle and did work fine with this code
Private Sub UltraMonthViewSingle1_DragDrop(ByVal sender As Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles UMonth.DragDrop
    Dim ClientPoint As New Point(e.X, e.Y)
    dItem = e.Data.GetData(GetType(String)).ToString()
    With Me.UMonth
        ClientPoint = .PointToClient(ClientPoint)
        .CalendarInfo.Appointments.Add(.GetDayFromPoint(ClientPoint).Date, dItem)
    End With
End Sub
Private Sub UltraMonthViewSingle1_DragEnter(ByVal sender As Object, ByVal e As System.Windows.Forms.DragEventArgs) Handles UMonth.DragEnter
    e.Effect = DragDropEffects.Copy
End Sub
now im trying to do the same but draging items from the explorerbar into a wingrid and is not working
when dragingover or enter it shows the denied image and dragdrop does not fire even when my allowdrop property is set to true.
i just want to drag items into my grid from the explorer bar and add new rows with the item name, sequence and some other data tha would be autopolulated
any idea? Thanks.
