290
Project upgrade utility 2010 vol2
I've some pb to upgrade VS2005 solution from 2009.2 to 2010.2.
I installed the service pack SR10_6 but it doesn't work.
Have an issue?
Log error :
System.FormatException: Le format de la chaîne d'entrée est incorrect.
   à System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
   à System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
   à System.Double.Parse(String s, NumberStyles style, NumberFormatInfo info)
   à Infragistics.VersionUtility.UI.AnalysisCompleteControl.BeginWork()
   à Infragistics.VersionUtility.UI.PrimaryForm.UpgradeHelper_UpdateStateChanged(Object sender, UpgradeStateChangedEventArgs e)
   à Infragistics.VersionUtility.UI.UpgradeHelper.UpdateCurrentUpgradeState(UpgradeState state)
   à Infragistics.VersionUtility.UI.UpgradeHelper.GoToNextState()
   à Infragistics.VersionUtility.UI.AnalyzeControl.backgroundWorker1_RunWorkerCompleted(Object sender, RunWorkerCompletedEventArgs e)
   à System.ComponentModel.BackgroundWorker.OnRunWorkerCompleted(RunWorkerCompletedEventArgs e)
   à System.ComponentModel.BackgroundWorker.AsyncOperationCompleted(Object arg)
