Hi.
I have form with 2 controls: WinGrid and UltraCalendarCombo.
WinGrid have editable column with decimal values.
Scenario:
1. Put incorrect value in cell, for example "hhh".
2. Mouse click on UltraCalendarCombo.
Problem: Error message shows two times.
Infragistics 10.1.20101.2013
How I can resolve this problem?Test form:
using System;using System.Data;using System.Windows.Forms;using Infragistics.Win.UltraWinGrid;namespace Test_Grid{ public class Form1 : Form { private Infragistics.Win.UltraWinGrid.UltraGrid ultraGrid1; private Infragistics.Win.UltraWinSchedule.UltraCalendarCombo ultraCalendarCombo1; /// <summary> /// Required designer variable. /// </summary> private System.ComponentModel.IContainer components = null; public Form1() { InitializeComponent(); } private void Form1_Load(object sender, EventArgs e) { DataTable dt = new DataTable(); DataColumn dataColumn = new DataColumn("decimal", typeof (decimal)) {Caption = "Decimal"}; dt.Columns.Add(dataColumn); dt.Rows.Add(1); dt.Rows.Add(2); dt.Rows.Add(3); dt.Rows.Add(4); ultraGrid1.DataSource = dt; } private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e) { e.Layout.Bands[0].Columns["decimal"].CellClickAction = CellClickAction.Edit; } /// <summary> /// Required method for Designer support - do not modify /// the contents of this method with the code editor. /// </summary> private void InitializeComponent() { Infragistics.Win.Appearance appearance4 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance1 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance2 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance3 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance12 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance7 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance6 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance5 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance9 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance11 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance10 = new Infragistics.Win.Appearance(); Infragistics.Win.Appearance appearance8 = new Infragistics.Win.Appearance(); Infragistics.Win.UltraWinSchedule.CalendarCombo.DateButton dateButton1 = new Infragistics.Win.UltraWinSchedule.CalendarCombo.DateButton(); this.ultraGrid1 = new Infragistics.Win.UltraWinGrid.UltraGrid(); this.ultraCalendarCombo1 = new Infragistics.Win.UltraWinSchedule.UltraCalendarCombo(); ((System.ComponentModel.ISupportInitialize)(this.ultraGrid1)).BeginInit(); ((System.ComponentModel.ISupportInitialize)(this.ultraCalendarCombo1)).BeginInit(); this.SuspendLayout(); // // ultraGrid1 // appearance4.BackColor = System.Drawing.SystemColors.Window; appearance4.BorderColor = System.Drawing.SystemColors.InactiveCaption; this.ultraGrid1.DisplayLayout.Appearance = appearance4; this.ultraGrid1.DisplayLayout.BorderStyle = Infragistics.Win.UIElementBorderStyle.Solid; this.ultraGrid1.DisplayLayout.CaptionVisible = Infragistics.Win.DefaultableBoolean.False; appearance1.BackColor = System.Drawing.SystemColors.ActiveBorder; appearance1.BackColor2 = System.Drawing.SystemColors.ControlDark; appearance1.BackGradientStyle = Infragistics.Win.GradientStyle.Vertical; appearance1.BorderColor = System.Drawing.SystemColors.Window; this.ultraGrid1.DisplayLayout.GroupByBox.Appearance = appearance1; appearance2.ForeColor = System.Drawing.SystemColors.GrayText; this.ultraGrid1.DisplayLayout.GroupByBox.BandLabelAppearance = appearance2; this.ultraGrid1.DisplayLayout.GroupByBox.BorderStyle = Infragistics.Win.UIElementBorderStyle.Solid; appearance3.BackColor = System.Drawing.SystemColors.ControlLightLight; appearance3.BackColor2 = System.Drawing.SystemColors.Control; appearance3.BackGradientStyle = Infragistics.Win.GradientStyle.Horizontal; appearance3.ForeColor = System.Drawing.SystemColors.GrayText; this.ultraGrid1.DisplayLayout.GroupByBox.PromptAppearance = appearance3; this.ultraGrid1.DisplayLayout.MaxColScrollRegions = 1; this.ultraGrid1.DisplayLayout.MaxRowScrollRegions = 1; appearance12.BackColor = System.Drawing.SystemColors.Window; appearance12.ForeColor = System.Drawing.SystemColors.ControlText; this.ultraGrid1.DisplayLayout.Override.ActiveCellAppearance = appearance12; appearance7.BackColor = System.Drawing.SystemColors.Highlight; appearance7.ForeColor = System.Drawing.SystemColors.HighlightText; this.ultraGrid1.DisplayLayout.Override.ActiveRowAppearance = appearance7; this.ultraGrid1.DisplayLayout.Override.BorderStyleCell = Infragistics.Win.UIElementBorderStyle.Dotted; this.ultraGrid1.DisplayLayout.Override.BorderStyleRow = Infragistics.Win.UIElementBorderStyle.Dotted; appearance6.BackColor = System.Drawing.SystemColors.Window; this.ultraGrid1.DisplayLayout.Override.CardAreaAppearance = appearance6; appearance5.BorderColor = System.Drawing.Color.Silver; appearance5.TextTrimming = Infragistics.Win.TextTrimming.EllipsisCharacter; this.ultraGrid1.DisplayLayout.Override.CellAppearance = appearance5; this.ultraGrid1.DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.EditAndSelectText; this.ultraGrid1.DisplayLayout.Override.CellPadding = 0; appearance9.BackColor = System.Drawing.SystemColors.Control; appearance9.BackColor2 = System.Drawing.SystemColors.ControlDark; appearance9.BackGradientAlignment = Infragistics.Win.GradientAlignment.Element; appearance9.BackGradientStyle = Infragistics.Win.GradientStyle.Horizontal; appearance9.BorderColor = System.Drawing.SystemColors.Window; this.ultraGrid1.DisplayLayout.Override.GroupByRowAppearance = appearance9; appearance11.TextHAlignAsString = "Left"; this.ultraGrid1.DisplayLayout.Override.HeaderAppearance = appearance11; this.ultraGrid1.DisplayLayout.Override.HeaderClickAction = Infragistics.Win.UltraWinGrid.HeaderClickAction.SortMulti; this.ultraGrid1.DisplayLayout.Override.HeaderStyle = Infragistics.Win.HeaderStyle.WindowsXPCommand; appearance10.BackColor = System.Drawing.SystemColors.Window; appearance10.BorderColor = System.Drawing.Color.Silver; this.ultraGrid1.DisplayLayout.Override.RowAppearance = appearance10; this.ultraGrid1.DisplayLayout.Override.RowSelectors = Infragistics.Win.DefaultableBoolean.False; appearance8.BackColor = System.Drawing.SystemColors.ControlLight; this.ultraGrid1.DisplayLayout.Override.TemplateAddRowAppearance = appearance8; this.ultraGrid1.DisplayLayout.ScrollBounds = Infragistics.Win.UltraWinGrid.ScrollBounds.ScrollToFill; this.ultraGrid1.DisplayLayout.ScrollStyle = Infragistics.Win.UltraWinGrid.ScrollStyle.Immediate; this.ultraGrid1.DisplayLayout.ViewStyleBand = Infragistics.Win.UltraWinGrid.ViewStyleBand.OutlookGroupBy; this.ultraGrid1.Location = new System.Drawing.Point(12, 56); this.ultraGrid1.Name = "ultraGrid1"; this.ultraGrid1.Size = new System.Drawing.Size(510, 194); this.ultraGrid1.TabIndex = 0; this.ultraGrid1.Text = "ultraGrid1"; this.ultraGrid1.InitializeLayout += new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.ultraGrid1_InitializeLayout); // // ultraCalendarCombo1 // this.ultraCalendarCombo1.DateButtons.Add(dateButton1); this.ultraCalendarCombo1.Location = new System.Drawing.Point(92, 12); this.ultraCalendarCombo1.Name = "ultraCalendarCombo1"; this.ultraCalendarCombo1.NonAutoSizeHeight = 0; this.ultraCalendarCombo1.Size = new System.Drawing.Size(121, 21); this.ultraCalendarCombo1.TabIndex = 1; // // Form1 // this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F); this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font; this.ClientSize = new System.Drawing.Size(534, 297); this.Controls.Add(this.ultraCalendarCombo1); this.Controls.Add(this.ultraGrid1); this.Name = "Form1"; this.Text = "Form1"; this.Load += new System.EventHandler(this.Form1_Load); ((System.ComponentModel.ISupportInitialize)(this.ultraGrid1)).EndInit(); ((System.ComponentModel.ISupportInitialize)(this.ultraCalendarCombo1)).EndInit(); this.ResumeLayout(false); this.PerformLayout(); } /// <summary> /// Clean up any resources being used. /// </summary> /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param> protected override void Dispose(bool disposing) { if (disposing && (components != null)) { components.Dispose(); } base.Dispose(disposing); } }}
Igor
hi, this double error message happens in the case of ultradatetimeeditor as well.. the error message is thrown twice.
Thanks, Mike.
Hi Igor,
This looks like a bug in the UltraCalendarCombo. After looking at it very briefly, it looks like perhaps the UltraCalendarCombo is processing the MouseDown message twice. I noticed that the problem does not occur with other controls, like UltraDateTimeEditor.
I am going to forward this thread over to Infragistics Developer Support so they can check it out.
