Hi, I am trying to have the minimum value on the Y-Axis as a negative value and make it the start of every column in a ColumnChart.
As example, I have, let's say, 5 values: (1,10); (2,15); (3,0); (4,-10); (5,-5). And I set the minimum value as -20 for example.
I want the chart to show me a bar that goes from
-20 to 10 for the first value; -20 to 15, for the 2nd; -20 to 0, -20 to -10 and -20 to -5.
It will be as if I had the -20 as the zero-base. I don't want the negative values to go downards and the positive upwards. Everything goes upwards starting at the value set.
Any ideas on how to achieve this?
Imad
Hi Petia,
thanks a lot for your help. I had to change some of your code since the 0-line might actually be in the positive or in the negative.
But your code did put me on the right track.
Here is the code that worked for me:
Dim xAxis As Infragistics.UltraChart.Core.IAdvanceAxis = Nothing
Dim b As Infragistics.UltraChart.Core.Primitives.Box
Dim zeroY As Single = 0
Dim fromStartToZero As Single = 0
Dim startPoint As Single = 0
xAxis = DirectCast(e.Grid("X"), Infragistics.UltraChart.Core.IAdvanceAxis)
For i As Integer = 0 To e.SceneGraph.Count - 1
If TypeOf (e.SceneGraph(i)) Is Infragistics.UltraChart.Core.Primitives.Box Then
b = e.SceneGraph(i)
If b.Value Is Nothing Then Continue For
If (...) Then 'Code to get the rect.Y of an item which value is 0
zeroY = b.rect.Y
startPoint = DirectCast(xAxis, Infragistics.UltraChart.Core.Layers.Axis).startPoint.Y
fromStartToZero = startPoint - zeroY
End If
If b.Value >= 0 Then
If fromStartToZero > 0 Then
b.rect.Height += fromStartToZero
'Else 'Do nothing since it is already shrunk to show only the needed part
Else
If b.rect.Y + b.rect.Height > startPoint Then
b.rect.Height = 0
b.rect.Y += b.rect.Height ' or the same result: zeroY + b.rect.Height
b.rect.Height = fromStartToZero - b.rect.Height
Next
Thanks again.
Hi Imad,
There is not a property which you can use to achive the desired functionality.
There are two approachies you can use to achive it manually:
- change the axis labels texts, i.e. 0 become -20 etc... or
- use FillSceneGraph event handler, get every box of the chart and change its rectangle height with the difference to the x axis. For example:
void ultraChart1_FillSceneGraph(object sender, Infragistics.UltraChart.Shared.Events.FillSceneGraphEventArgs e){ IAdvanceAxis xAxis = (IAdvanceAxis)e.Grid["X"]; for (int i = 0; i < e.SceneGraph.Count; i++) { Box b = e.SceneGraph[i] as Box; if (b != null) { Rectangle currentRect = b.rect; int difference = (xAxis as Axis).startPoint.Y - currentRect.Y; currentRect.Height = currentRect.Height + difference; b.rect = currentRect; } }}
Let me know if you need further assistance.
