490
Upgrading from Infragistics 8.2 to 10.2
i have to upgrade my Solution from Infragisitcs v 8.2 to v10.2 , i uses the dll of NCEK as well in my solution like Infragistics.Practices.CompositeUI.Winforms, Microsoft.Practices.COmposite,CompositeUI.Winform, Object Builder .i uses the Version utility that comes with the Infragistics 2010.2 but as solution updates it gives me following error message
10:07:04: Gathering volume and assembly information.
10:07:10: Analyzing Infrastructure.Interface.csproj...
10:07:10: Nothing for us to upgrade.
10:07:10: Analyzing Infrastructure.Library.csproj...
10:07:10: The following project needs to have its references updated:
10:07:10: Analyzing Infrastructure.Module.csproj...
10:07:10: Analyzing Shell.csproj...
10:07:10: Analyzing Infrastructure.Layout.csproj...
10:07:10: Analyzing LoginModule.csproj...
10:07:10: Analyzing OutputControl.csproj...
10:07:10: Analyzing ERM.csproj...
10:07:10: Analyzing ERM.Interface.csproj...
10:07:10: Analyzing Common.csproj...
10:07:10: Analyzing StartupModule.csproj...
10:07:10: Analyzing StartupModule.Interface.csproj...
10:07:10: Analyzing StartupPageLoaderModule.csproj...
10:07:10: Analyzing AccountsGroupOptimizationSettings.csproj...
10:07:10: Analyzing AccountsSettingsExtension.csproj...
10:07:10: Analyzing GroupsSettingsExtension.csproj...
10:07:10: Analyzing SecurityManager.csproj...
10:07:10: Analyzing DTOPROBEModel.csproj...
10:07:10: Analyzing ReportCenter.csproj...
10:07:10: Analyzing ReportCentre.Interface.csproj...
10:07:10: Analyzing ERMSettings.csproj...
10:07:10: Analyzing ERMSettings.Interface.csproj...
10:07:10: Analyzing StrategyManagement.csproj...
10:07:10: Analyzing StrategyManagement.Interface.csproj...
10:07:11: Upgrading Solution PROBEDemo.sln
10:07:11: Updating Infrastructure.Library.csproj...
10:07:11: Infrastructure.Library.csproj has been backed up.
10:07:11: Object reference not set to an instance of an object.
10:07:11:    at Infragistics.VersionUtilitySupport.Core.File.Types.ProjectFile.Upgrade(String rootDirectory)
10:07:11: Infrastructure\Shell\Properties\licenses.licx has been backed up.
10:07:11: Infrastructure\Infrastructure.Layout\Properties\licenses.licx has been backed up.
i don't know exactly where i am doing wrong, Kindly help me out.you help will be highly appreciated
