I have an UltradesktopAlert that I'm using in in conjuction with teh UltraDesktopAlertWindowInfo object. I create several window info objects and display them - tiled. At times the users do not want these to appear on the right hand side of their screen so they move them to the left side. This works fine until they try to dock the alerts to eachother. Once they start docking them to eachother the error is thrown usually about the 4th alert to be docked causes the error to be thrown.
Has anyone else experienced this or have any idea why this is happening and how to avoid it?
We have created the following case for you : CAS-51568-4RQ8JN
I will notify you through your case for our progress on your issue.
Please do not hesitate to contact us if you have any other questions.
Any update on the status of this case?
Joe
Hello Joe.
Just to let you know that your issue is fixed in the latest service release.
If you have any other question do not hesitate to ask.
