I'm wondering if it is possible to always show the add row at the top of the grid, even when rows are grouped. I have my add row set like this:
e.Layout.Override.AllowAddNew = AllowAddNew.FixedAddRowOnTop;
This is fixed at the top, but once I drag a column into the group header area, I no longer have an add row showing. I would like the add row to show right above all the grouped rows. Is this possible?
~Corey
Hi Corey,
It may be 'possible' to do this, but it's really not realistic. Simply creating the UIElement would not be enough, you'd have to somehow associated it with a row in the underlying data source and handle all sorts of issues. It would be a huge amount of code.
It would be probably be easier to use a second grid bound to the same data source with no group and just show a single TemplateAddRow then to try to get it into the same grid.
Mike,
I have submitted a feature request for this. I have been trying to find a way to implement the functionality that we want by using a CreationFilter. My theory was that I can Offset some of the UIElements in the grid to create a space where I can create my own custom template add row that will always show in the grid even when grouping. I have successfully created this space by using the following code:
public void AfterCreateChildElements(UIElement parent)
if (parent is RowColRegionIntersectionUIElement)
foreach (UIElement element in parent.ChildElements)
if (!(element is BandHeadersUIElement))
element.Offset(0, 23, true);
This provides me with the space I need to attempt to add my own set of controls to mimic an add row. From the BandHeadersUIElement I can get each visible ColumnHeader and the Editor that is used for that column. My problem is that I can't seem to create those editor controls and add them as child elements of the RowColRegionIntersectionUIElement. Is it even possible to do this? I have tried many different things here. It seems like you can only add simple things like text, images, and buttons. What I really want to do is add my own row here, or add a series of controls that match the editor for the column and I can size and space them accordingly. (dates, combos, etc)
With all my efforts I am starting to think this isn't possible to do, but I wanted to post first to verify.
Thanks for your help,
The TemplateAddRow is not supported when the grid is grouped. You should Submit a feature request to Infragistics
