220
UltraWinTree with embedded ProgressBarEditor not showing % label
Hi.
I am using 10.2 Winforms and have a databound UltraWinTree with a ProgressBarEditor added succesfully using tv_ColumnSetGenerated.  The ProgressBarEditor is populated with a percentage in the tv_InitializeDataNode and the progressbar graphics show perfectly.  What I can't get to work is getting a label / text to show with the percentage in text.
My code so far:
Private Sub tv_ColumnSetGenerated ....
  ' Add additional columns
    Dim Status As Infragistics.Win.UltraWinTree.UltraTreeNodeColumn = e.ColumnSet.Columns.Add("Status")
  ' Create the ProgressBarEditor
  Dim pbe as new Ingragistics.Win.UltraWinProgressBar.ProgressBarEditor
  Status.Editor = pbe
End Sub
Private Sub tv_InitializeDataNode ...
  if e.Reinitialize then Exit Sub
  Dim StatusCell as Infgragistics.Win.UltraWinTree.UltraTreeNodeCell = e.Node.Cells(e.Node.DataColumSetResolved.Columns("Status"))
  if StatusCell is nothing then Exit Sub
  Dim pbe as Infragistics.Win.UltraWinProgressBar.ProgressBarEditor
  If StatusCell.EditorResolved IsNot Nothing then
    pbe = StatusCell.EditorResolved
  else
    pbe = new Infragistics.Win.UltraWinProgressBar.ProgressBarEditor
  end if
  pbe.Minimum = 0
  pbe.Maximum = 100
  StatusCell.Value = 50 ' This is normally the calculated value, but 50% shown as an example
End Sub
Any ideas on how I can get the progress bar to show the graphic, and some text behind it would be appreciated.  I've tried setting the ProgressBarEditor.Label, but I seem to get the same label value showing for every progressbar on the UltraWinTree.
A partial screenshot of what I am trying to achieve (i.e no text visible) is shown below:
Thanks!
Gary Burgess
