I have UltraDateTimeEditor with spin button style enabled. It shows only the time part of the Date. When i change the time using the up arrow or the up-spin button keeping the focus in the seconds suppose say till 9:59 and after that if the press the up-spin button then the up-spin button gets disabled and time remains same.
Is there any way whether i can make the time to show as 10:00 after i press the up-spin button at 9:59?
Thank you very much for the reply
No, the value in one section of the mask does not cause the value in another section to change.
