I have an UltraGrid with several columns some of them have the sum function activated. This works pretty well but if i group the list the sums are only there for the groups and the overall sum disappears. Is there any way to keep the overall sum visible?
A kinda related issue also bothers me. Is there a default behavior for displaying how many rows are displayed or do i have to do this manually?
thanks in advance
Thanks! That worked perfectly.
Use the SummaryDisplayArea property on the band. It's a flags enum, so you can add in multiple settings. The one you need for grand totals is GroupByRowsFooter.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Override.SummaryDisplayArea = SummaryDisplayAreas.Bottom | SummaryDisplayAreas.GroupByRowsFooter; }
