1255
Column header text alignment
Hi,  I have a column on the grid with the property  Header.Appearance.TextHAlign  set to HAlign.Left, but when I hover the mouse over the header,  the text moves to middle  automatically. I need it stay left.   How do I resolve it  ?
 Mouse hover over,  now the header text moves by itself:
  • 370
     I tried reproducing the issue using the following code but was not able to reproduce it.
    private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
         e.Layout.Bands[0].Columns[0].Header.Appearance.TextHAlign = HAlign.Left;
     Can you please attach a small sample with which the issue can be reproduced. Also, may I know which version of Netadvantage are you using.
    Vaibhav
