130
GridColumnCollection.Contains Failed to test GridColumn
My UltraWinGrid (V 9.1) behaves weird: the first screen shot show that the grid has 5 columns
however the following code:
grid.DisplayLayout.BandsSerializer[0].Columns.Contains("Gas") failed!
as screen shot 2 why?
  • 469350
    Verified Answer
    This code fails because you are passing in a string. The Columns collection does not contain any strings, it contains a UltraGridColumn objects.
    You should be using the Exists method to see if a column exists with the specified key.
  • 130
    Resolved with following code; but I still don't know why the previous one failed:
    foreach(var  col in grid.DisplayLayout.BandsSerializer[0].Columns)
        if( col.Key.Equals("Gas"))
               col.Width = iPresetValue;
  • 130
    I've read Mike's post, he suggested not to use BandsSerializer. But my case is to resume stored Grid display information (column width etc)
