My UltraGrid is bound to a DataTable which doesn't allow Null values in some columns. Even though I don't want to allow the user to update the DataTable when there are some errors :
I already got a good idea how I'm going to make the 3rd point happen (Infragistics Documentation) but I have no clues for the first two.
Can anyone point me in the right direction please?
For point one please handle ultraGrid1_CellDataError event and add the following code there:
e.RestoreOriginalValue = true;//restore the previous value
e.RaiseErrorEvent = false;//determine if the popup should pop
e.StayInEditMode = false;// determine if the cell should stay in edit mode
For point two I think that you just should allow add new and allow update (by default the grid is editable). You could allow these properties with
this.ultraGrid1.DisplayLayout.Override.AllowAddNew = Infragistics.Win.UltraWinGrid.AllowAddNew.TemplateOnTop;
this.ultraGrid1.DisplayLayout.Override.AllowDelete = Infragistics.Win.DefaultableBoolean.True;
this.ultraGrid1.DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.True;
