519
"Parameter is not valid" exception in OnPaint() in Ultragrid
Hi ,
I am getting Parameter is not valid exception while calling onPaint().
 base.OnPaint(pe);
There are multiple grid using a custorm grid which is calling this method.
I am resetting the grid layout for all the grids with the help of LoadFromXml() , which causes a call to onpaint() .
When i check the parameters , i see
X and Y are 0,0 ...not sure if this is the cause.
Stack Trace is somthing like this :
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Image.get_Width()
   at Infragistics.Win.UltraWinScrollBar.ScrollThumbUIElement.DrawImage(UIElementDrawParams& drawParams)
   at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams)
   at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
   at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
   at Grid.OnPaint(PaintEventArgs pe) in 325
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer, Boolean disposeEventArgs)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Ashish.
  • 469350
    Hi Ashish,
    What version of the grid are you using? Do you have the latest service release?
    Exactly what X and Y parameters are you referring to? I doubt that any X or Y would have anything to do with this exception. Most likely, this is either a bug in the grid, a threading issue in your application, or you are trying to use an image in the grid and that image was disposed for some reason.
    Can you duplicate this exception in a small sample project?
