490
UltragridRowLayout together with merge cells
i have a scenario in which i have to display data in the ultragrid in such a way that ultragridRow layout style should be used together with some merged cells but unforturnately i did'nt get the desired result, i first applying row layout info to the cells and then apply merged cells to the grid but the merging of cells does not seems to work,kindly help me out if these two features can be used together, and if yes then what should be done first either the rowlayout info to the grid applied first or the merge cell settings should be applied first
any sort of help will be highly appreciated
Regards
