115
terrible performance when using a UltraControlContainerEditor with a transparent background
I'm using a custom control in an ultragrid column, defined like this :
UltraControlContainerEditor container = new UltraControlContainerEditor();
container.RenderingControl = new MyControl();
 cols["MyColumn"].EditorComponent = container;
 cols["MyColumn"].CellDisplayStyle = CellDisplayStyle.FullEditorDisplay;
the grid's row appearance is defined with a gradient like this
UltraGrid.DisplayLayout.Bands[0].Override.RowAppearance.BackColor = System.Drawing.Color.White;
UltraGrid.DisplayLayout.Bands[0].Override.RowAppearance.BackColor2 = System.Drawing.Color.FromArgb(191, 219, 255);
UltraGrid.DisplayLayout.Bands[0].Override.RowAppearance.BackGradientStyle = Infragistics.Win.GradientStyle.Vertical;
MyControl has a transparent background, and the performance is terrible (scrolling is laggy, resizing the grid takes up to 5 seconds, etc.). If I switch MyControl's backcolor to a plaincolor (eg white), the performance is smooth again.
I've found the performance bottleneck seems to be MyControl's OnPaintBackground method : It seems to be called a ridiculous number of time. Entering a cell results in 3 calls, as does leaving a cell ; scrolling just one row down leads to 3-4 calls to OnPaintBackground for every visible cell, while I would have excepted only one call to the newly visible cell.
Overriding this method and doing nothing in it results in smooth performance, but I've got some visual artefacts here and there, so this doesn't seem to be a viable option.
I've also considered using an ultrapanel as MyControl's background, and applying it the same kind of gradient as the grid does, but It's a nightmare to keep the gradient in sync with the current row (which can be selected, or highlighted, etc.)
Is there something I can do to optimize this ? Is this a known issue ?
