504
UltratreeNode image not updated when property is modified
I am building a tree from a background worker, so that the user sees the tree build up "live". For nodes that are not completely filled, I want to temporarily change their default image for a "loading" image. When a node gets all its child nodes, its image is reset to default.
Here is my code :
// initialize node
node.Override.NodeAppearance.Image = index;
// now child nodes are to be added : change image to "loading"
node.Override.NodeAppearance.Image = (Image)Properties.Resources.ResourceManager.GetObject("loading"));
treeView.Refresh();
// tree loaded : reset initial image index
However, this does not work : all nodes keep their initial image. Even with the tree refresh I cannot see my "loading" picture.
Thank you for your help !
Parents Reply Children
No Data
