Is there a way to select notes from a drop down?
I have a predefined set of notes that I need to be able to chose from. I have tried using a value list but I cant get it to show a drop down.
The same value list will show as a drop down if I use the resources column.
Code and screen shot:
this.ultraGanttView1.GridSettings.ColumnSettings[TaskField.Resources].Text = "(Resources)";
this.ultraGanttView1.GridSettings.ColumnSettings[TaskField.Resources].ValueList= NoteList();
this.ultraGanttView1.GridSettings.ColumnSettings[TaskField.Notes].Text = "(Notes)";
this.ultraGanttView1.GridSettings.ColumnSettings[TaskField.Notes].ValueList = NoteList();
Is there a way to set the DropdownStyle to DropDownList? I dont want users to be able to enter data other than whats in the valuelist
By default that column uses our FormattedTextEditor so that you can display rich text in the cell. Add the following code to assign an EditorWithCombo:
this.ultraGanttView1.GridSettings.ColumnSettings[TaskField.Notes].Editor = new EditorWithCombo();
