I downloaded NetAdvantage_WinClientWithSamplesAndHelp_20102.exe and when I double click I get:
"Infragitstics.Wrapper.Interface has encountered a problem and needs to close. We are sorry for the inconvenience." and it closes out.
Please help.
I got the same error on install NetAdvantage_WPFWithSamplesAndHelp_20103..
(I also try to test your all standart answers, like IIS 6.0 compatiblity has installed, UAC is disabled, Run as Administrator, Compatibility With WinXP SP3 )
there is no log file in application data..
My system is Windows 7 64 bit, visual studio 2010 32 bit. And the worser one is that we publish our sample infragistics project ( just an empty form and un boung grid), the publish exe got same error on Windows 7 64 bit client machine...
On debug, the exception is:
System.TypeInitializationException was unhandledMessage: The type initializer for 'Infragistics.Wrapper.Interface.Program' threw an exception.
Description: Stopped workingProblem signature: Problem Event Name: APPCRASH Application Name: NetAdvantage_WPFWithSamplesAndHelp_20103.exe Application Version: 10.3.20103.1002 Application Timestamp: 4cb6f2d5 Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7600.16385 Fault Module Timestamp: 4a5bdbdf Exception Code: e0434f4d Exception Offset: 0000b727 OS Version: 6.1.7600.2.0.0.256.48 Locale ID: 1055Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt
Is anything being written to the log file I referred to? Also, if you get that dialog offering to debug again, click the Debug button and see if it reports a more specific message. You may be getting an exception that'll more clearly explain what is occuring.
Also, in case this may be an issue with the particular package you're running on your machine. there is also a "NetAdvantage_WinClient_20102.exe" package available. It's the same product, but the help and samples can be downloaded separately in it rather than being included directly in the EXE.
I am unable to install first, only after that i can debug, etc.,
I am trying to install "NetAdvantage_WinClientWithSamplesAndHelp_20102.exe"
467 MB (489,752,448 bytes)
File Version : 10.2.20102.1009
I have installed .NET Framework 1.1, 2.0 and 3.5
Which .NET Frameworks are installed on the machine? If you try and debug the error, do you get a more precise error reported? Does the log file contain any information about the error? You can find the log file in your local application folder, C:\Documents and Settings\(user name)\Local Settings\Application Data\Infragistics\Wrapper\IGWrapper.log.
I am also facing the same issue.. I downloaded "netadvantage_winclientwithsamplesandhelp_20102.exe", when i try to install, after few mins it crashes..
I am using Windows XP SP3. Screenshot attached.
