4160
Loading from a table that uses a HierarchyID column
Hello
Suppose that in a SQL Server 2008 database there is a table MyNodeTable(#NodeKey, NodeName) where the NodeKey column is of type HierarchyID. What would be the recommended way of loading an UltraTree control from this table?
Thanks a lot.
  • 469350
    How you load the tree with data depends on the needs of your application. But you basically have two options.
    1) Bind the tree to a data source containing the data you want.
    2) Loop through the data and add the nodes to the tree in code.
