I am having trouble with an autocomplete cell on my grid.
If I have values in the autocomplete list like:
applebannanaAnd you want to type 'Assign' the first letter gets forced to lower case. If you have upper case values it's the same problem typing lower case. This is a real problem as we want a list of lower case words in the valuelist but allow the user to override it by typing something else that is often a person's name which needs to be capitalized.
I have no idea where to start to fix this?
I don't see any way around this unless you turn of the AutoComplete. The user can go back and change the "A" to a capital after they have entered text that doesn't match, but typing in an "A" initially will always match to the item on the list and change the case.
