40
Errors with C# and Infragistics
Hello
I have a solution in VS 2008 C # which is composed of six projects and uses. NetAdvantage for graphics.
When I start to debug to see if the solution runs properly, show a series of errors like the following:
65 Error exception to create the type 'Infragistics.Win.UltraWinToolbars.UltraToolbarsManager, Infragistics2.Win.UltraWinToolbars.v8.3, Version = 8.3.20083.1009, Culture = neutral, PublicKeyToken = 7dd5c3163f2cd0cb' System.ComponentModel.LicenseException
C: \ Solucion1 \ Proyecto1Properties \ licenses.licx line 7
In total there are 3 files called licences.licx in the solution, each containing the names of the components used by the project in question, approximately 10 per file and each one marks me an error (30 errors total), my question is :
How I can fix them?
As additional data, I use the following tools Infragistics:
NetAdvantage for. NET 2008 Volume 3 CLR 2.0
NetAdvantage for. NET 2008 Volume 3 CLR 3.5
NetAdvantage for WPF 2008 Vol 2
Would like to know if they have downloads available on the site because I searched and I have not found it.
