Hi all,
I have a problem with freezing one column on my grid. I am following rules doing this:private void ultraGrid1_InitializeLayout(object sender, InitializeLayoutEventArgs e){ e.Layout.UseFixedHeaders = true; // Fix the second column. This will cause this column to be moved before any // non-fixed columns. e.Layout.Bands[0].Columns[0].Header.Fixed = true;}It seems that is not enough to work. I can still scroll first column on my grid.I have my grid and UltraDataSource linked with this grid which I am providing with data ( I have designed whole layout and data structure in ) for this grid.Maybe that is the problem.Any suggestions ?
Piotr
Hi Piotr,
The grid does not support fixed headers in RowLayout mode. There's no way to do it.
Why are you using RowLayouts? Perhaps you don't need to.
Hi Mike,
That is true I am using RowLayouts in my Grid. As I understand there is no way using RowLayouts to make my requirments come true or there is any way to implement this ?
Regards
I don't see anything wrong with this code, so there are only two reasons I can think of why this would not work:
1) Something in your code that occurs after this is undoing it. Perhaps you are loading a layout into the grid after this code fires?
2) You are using RowLayouts. RowLayouts and fixed headers are mutually exclusive.
Of course in my example need to be word fist column instead of second column.
