105
License issues when embedding a designer in my application.
I have a simplified form designer which allows a user to create basic forms using a limited control set.  These controls are derived from a selection of Infragistics controls (UltraTextBox, UltraCheckBox etc).  When the user saves the form it is serialized to xml, then my main application displays the form when a new report is created.  This way, a customer can tweak the forms to suit their workflow.
The problem is that when deployed on a customer site, an exception is thrown when a control is added to the designer because the license key is not installed on the machine:
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ComponentModel.LicenseException
   at Infragistics.Shared.UltraLicenseProvider.GetDesignTimeLicense(Type type, Object instance, Boolean allowExceptions, UltraLicenseBaseAttribute licenseAttribute)
   at Infragistics.Shared.UltraLicenseProvider.GetLicense(LicenseContext context, Type type, Object instance, Boolean allowExceptions)
   at System.ComponentModel.LicenseManager.ValidateInternalRecursive(LicenseContext context, Type type, Object instance, Boolean allowExceptions, License& license, String& licenseKey)
   at System.ComponentModel.LicenseManager.Validate(Type type, Object instance)
   at Infragistics.Win.UltraWinEditors.UltraTextEditor..ctor()
How can I avoid this?
Thanks.
  • 71886
    Hello philipw,
    A possible reason for this issue could be that the design-time license check performed by Visual Studio on your user control also performs a design-time license check on any controls it contains (including Infragistic's).  If you do not have our toolset installed, this design-time licence check fails with the error message you've mentioned.
    Please do not hesitate to contact us if you need any additional assistance.
