I have a solution in VB.NET .NET 2
Use Infragistic componets all over the application.
One day decided to add floating toolbar support to our Forms.
Our forms inherit one base form BaseForm. This base form is used in multiple projects in the solution.
So, on the BaseForm was added a UltraToolbarsManager.
Since, a nightmare began: the licenses.licx started to create and add itself to the project on every form opened in designer....
licence.licx contains:
Infragistics.Win.UltraWinToolbars.UltraToolbarsManager, Infragistics2.Win.UltraWinToolbars.v6.3, Version=6.3.20063.53, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
What to do?
Hello serhiol,
What you could do is to remove the content of the Licenses.licx file, which is located under the "Properties" folder in your application. Then please clean and rebuild your solution and feel free to let me know if something comes up.
