is there any function equivalent to
treeView.Nodes.Find in ultratree.
Also is there any property equivalent to TreeNode.Name there is only Text property in Infragistics.Win.UltraWinTree.UltraTreeNode
Dibya, It sounds like you are after:
UltraTreeNode nodeToFind = ultraTree.GetNodeByKey(nodeKey)
Where nodeKey will be the string key of the node you are looking for.
and:
The ultraTreeNode class has a .Key property which is the unique identifier of the node within the node hierarchy. This is the closest thing to a name property.
