545
Using UltraDataSource instead of DataSet
I need to read a large xml file and show it using a WinGrid. Now i use a DataSet.
I created a xsd schema and created the DataSet with MSDataSetGenerator (VS2008)
I read that the UltraDataSource has some advantages over the DataSet. Is it possible to create a schema for the UltraDataSource as easy as with MSDataSetGenerator.
The only option i could find was the 'UltraDataSource  Designer'.
Because it's a complicated xml file, i don't like to create it using the 'UltraDataSource  Designer'.
I'm missing something ?
