1871
NavigationOverflowButtonArea GroupClick event is not firing.
When the buttons are visible on the screen and I click on the button the GroupClick event fires. The same is not true when I click on the overflow button and click an item from the overflow list. Which event should I be checking? Hopefully the images will help explain my issue. When I save off the Explorer Bar settings how do I over write them if a new item is added?
Group Click Event Fires if I click on any of the icons below.
Group Click Does Not Fire if I click on Report Viewer.
