Hello.
I created a datatable with 3 columns (datetime, int1, int2) and bind it to my chart.
Now i want to display the value of each column on the column itself, but i think there is a bug or something (only one column displays its value).
source code:
for (int i = 0; i < 10; i++) { chart.ColumnChart.ChartText.Add(new Infragistics.UltraChart.Resources.Appearance.ChartTextAppearance()); chart.ColumnChart.ChartText[i].ItemFormatString = "<DATA_VALUE:00.##>"; chart.ColumnChart.ChartText[i].Row = i; chart.ColumnChart.ChartText[i].Column =0; chart.ColumnChart.ChartText[i].VerticalAlign = StringAlignment.Center; chart.ColumnChart.ChartText[i].Visible = true; } for (int i = 0; i < 10; i++) { chart.ColumnChart.ChartText.Add(new Infragistics.UltraChart.Resources.Appearance.ChartTextAppearance()); chart.ColumnChart.ChartText[i].ItemFormatString = "<DATA_VALUE:00>"; chart.ColumnChart.ChartText[i].Row = i; chart.ColumnChart.ChartText[i].Column = 1; chart.ColumnChart.ChartText[i].VerticalAlign = StringAlignment.Far; chart.ColumnChart.ChartText[i].Visible = true; }
Image:
(note: that i want the value appear in the pink & in the green columns)
Thanks in advance...
solution found.
we have to create only 1 ChartTextAppearance() and set its Row and Column (each) to -2.
That's fixes the problem....
