I'm trying to create functionality similar to the UltraGrid's drag a column off the control to remove the column. What I want to be able to do is:
1. Drag a group off of the control and have that group removed.
2. Change the cursor to the same 'X' cursor that the UltraGrid uses when a group is dragged out of the control.
Is the functionality for #1 built in somewhere, or will I have to implement all the drag/drop events myself (including the drag a group to reposition its order)?
Trung
Thanks Brian. I've been able to implement the behavior that I need except for the cursor. How can I go about changing the cursor to the same one used by UltraGrid when a column is dragged out of the control to remove it?
Group dragging within the control is supported intrinsically (see UltraExplorerBar.GroupSettings.AllowDrag), however, external dragging is not.
