I want to display a combined chart consisting of a column chart and stack column chart. I want to display the plan numbers for budget, forecast, request and actual data for each month. Therefore I need four bars for each month. In addition I want to display the request data as a stacked bar. This is the point where I get into troubles. I have no idea how to combine these chart types in order to get a stacked bar for the request data. Any suggestions?
Here is an illustration of my purpose:
There is also a post that demonstrates how to create a similar chart here:http://forums.infragistics.com/forums/p/2886/81241.aspx
Hello Jeorg,
Did my suggestion answer your question? If so, verify it so other users with the same question can find the answer.
Hello Joerg,
You might want to look into the Layers framework that's available with the WinChart. See the link below.
http://help.infragistics.com/NetAdvantage/WinForms/2010.2/CLR2.0/?page=Chart_About_Custom_Layers.html
