Hi all,
I have got a query regarding merging the cells of specific column. Currently i can only merge the cells if I sort that column.
but I want to merge to merge the cells as per need or user preference and without sorting.
Another question is given cell information how can I merge them?
plz help me out
Thank you all
Hi Yogesh
I have asked the same question in this forum only but Infragistic R&D Engineer said me the same answer. you can check that issue by click on following link http://forums.infragistics.com/forums/p/4365/21087.aspx#21087
Using handler how to do this i dont know. even i have changed my code and implement that in another way.
Thanks a lot Hiren ,
You mean to say that we cant merge the cells from the specific column given the cell information that we want to merge..
is tere any other way out to this even programatically getting the handle to column or like that so that I can forcably do the way i am trying
Yogesh
You cannot span on a row-by-row basis. The grid does not support this. You should submit a feature request to Infragistics.Request a Feature or Component
