Sometimes during the working an exception occurs in week view, when we drag some appointment or just click on appointmetn object.
Stack trace is given below.
" at Infragistics.Win.UltraWinSchedule.ScheduleDrawUtility.SetDayHeaderAppearancePropertyDefaultValuesOffice2007(Outlook2007ColorScheme colorScheme, Boolean isToday, Boolean isHotTracking, AppearanceData& defaultAppData)\r\n at Infragistics.Win.UltraWinSchedule.UltraMonthViewSingle.ResolveDayHeaderAppearance(DateTime date, AppearanceData& appData, AppearancePropFlags& requestedProps, Owner owner, Boolean isHotTracking)\r\n at Infragistics.Win.UltraWinSchedule.MonthViewSingle.DayNumberUIElement.InitAppearance(AppearanceData& appearance, AppearancePropFlags& requestedProps)\r\n at Infragistics.Win.UltraWinSchedule.MonthViewSingle.DayNumberUIElement.AddChildUIElements(UIElementsCollection oldElements)\r\n at Infragistics.Win.UltraWinSchedule.MonthViewSingle.DayNumberUIElement.PositionChildElements()\r\n at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)\r\n at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)\r\n at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)\r\n at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)\r\n at Infragistics.Win.UIElement.VerifyChildElements()\r\n at Infragistics.Win.UltraWinSchedule.UltraMonthViewSingle.OnSelectedActivitiesChanged(SelectedActivitiesCollectionBase selectedActivities)\r\n at Infragistics.Win.UltraWinSchedule.UltraMonthViewSingleBase.OnCalendarInfoChanged(CalendarInfoChangedEventArgs args)\r\n at Infragistics.Win.UltraWinSchedule.UltraMonthViewSingle.OnCalendarInfoChanged(CalendarInfoChangedEventArgs args)\r\n at Infragistics.Win.UltraWinSchedule.UltraMonthViewSingleBase.OnCalendarInfoChanged(Object sender, CalendarInfoChangedEventArgs args)\r\n at Infragistics.Win.UltraWinSchedule.CalendarInfoChangedEventHandler.Invoke(Object sender, CalendarInfoChangedEventArgs e)\r\n at Infragistics.Win.UltraWinSchedule.UltraCalendarInfo.OnCalendarInfoChanged(CalendarInfoChangedEventArgs e)\r\n at Infragistics.Win.UltraWinSchedule.UltraCalendarInfo.FireCalendarInfoChangedEventHelper(PropChangeInfo propChangeInfo, PropertyIds propId)\r\n at Infragistics.Win.UltraWinSchedule.UltraCalendarInfo.OnSubObjectPropChanged(PropChangeInfo propChangeInfo)\r\n at Infragistics.Shared.SubObjectBase.NotifyPropChange(PropChangeInfo trigger)\r\n at Infragistics.Shared.SubObjectBase.NotifyPropChange(Enum propId)\r\n at Infragistics.Win.UltraWinSchedule.SelectedActivitiesCollectionBase.ContentsChangedHelper(ContentsChangeType contentsChangeType, SubObjectBase[ activities, Boolean clearExisting)\r\n at Infragistics.Win.UltraWinSchedule.SelectedActivitiesCollectionBase.AddHelper(SubObjectBase[ activities, Boolean clearExisting)\r\n at Infragistics.Win.UltraWinSchedule.UltraMonthViewSingleBase.Infragistics.Win.ISelectionManager.SelectItem(ISelectableItem item, Boolean clearExistingSelection)\r\n at Infragistics.Win.SelectionStrategyExtended.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo, Boolean forceDrag)\r\n at Infragistics.Win.SelectionStrategyExtendedAutoDrag.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo)\r\n at Infragistics.Win.SelectionStrategyExtended.OnMouseMessage(ISelectableItem item, MouseMessageInfo& msginfo)\r\n at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e)\r\n at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e)\r\n at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)\r\n at Infragistics.Win.UltraControlBase.OnMouseDown(MouseEventArgs e)\r\n at Infragistics.Win.UltraWinSchedule.UltraMonthViewSingleBase.OnMouseDown(MouseEventArgs e)\r\n at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)\r\n at System.Windows.Forms.Control.WndProc(Message& m)\r\n at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)\r\n at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)\r\n at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)\r\n at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)\r\n at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)\r\n at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)\r\n at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)\r\n at System.Windows.Forms.Application.Run()\r\n at Coronado.Framework.PFM.Program.Main() in C:\\Coronado Versions\\BetaRelease1700\\desktop\\Framework\\PFM\\Program.cs:line 79\r\n at System.AppDomain.nExecuteAssembly(Assembly assembly, String[ args)\r\n at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[ args)\r\n at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()\r\n at System.Threading.ThreadHelper.ThreadStart_Context(Object state)\r\n at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)\r\n at System.Threading.ThreadHelper.ThreadStart()"
DeclaringType: {Name = "ScheduleDrawUtility" FullName = "Infragistics.Win.UltraWinSchedule.ScheduleDrawUtility"}
How to handle this exception. Kindly help.
No yet. I have inserted TRY/CATCH blocks in the WinScheduleDayDrawFilter and SymbolsCreationFilter classes, but no success yet..
I get exactly the same in same circumstances, have you had any resolution?
It is occuring randomly. If I work in a such environment where owners are not attached t calendarinfo, it does not happen. But when I work with multiple owner, this crash happens.
It doesn't say here what the exception was, but I took a look at the code and the only thing I saw in the SetDayHeaderAppearancePropertyDefaultValuesOffice2007 method that could cause an exception is if the caller passed a null reference to the colorScheme parameter, which is theoretically impossible because the default scheme is used when owners are not displayed. You should report this via the web support form so you can provide the details necessary in order to reproduce the problem (i.e., a test project).
