180
UltraTabControl MouseOver styling
I am trying to use the AppStylist for a WinForms app but can't find the setting for the Hover event for the Tab.  Can this be done in the AppStylist, or do I have to set it in code?
  • 53790
    The desire behavior can be achieved using the properties:
    -          ultraTabControl1.UseHotTracking = Infragistics.Win.DefaultableBoolean.True;
    -          ultraTabControl1.SelectedTabAppearance
    -          ultraTabControl1.HotTrackAppearance
    The same appearance could be achieved also by using the AppStylist. Please follow the steps below if you want to use AppStylist:
    1.       Run your AppStylist
    2.       Select “Tabs” from right window
    3.       Hover the mouse over TabControl, tab caption area – for example over the text “tab 1”
    4.       Press key “C”
    5.       Take a look at the Property window and set property “UseHotTracking = True”
    6.       Repeat again the steps 3 and 4, then press key “1”
    7.       Take a look again in the property window. There are different properties depending of the Tab`s state. You could set properties “HotTracked” and “HotTrackSeleced”
    Please if you have any questions, do not hesitate to ask me
    Regards
