While developing I noticed a small bug in the way the tooltips are displayed for buttons on the ribbon. When I start my app it all works well; the tooltips appear while hovering the buttons. But when I drag and drop the entire form to my secondary monitor (extended desktop) the tooltips appear empty (without any text in them).
Perhaps this is already fixed in the current versions (I'm using build 7.1.20071.1055) but I thought you would mind me mentioning it ;)
Cheers!
That's indeed the case! I'll report the issue, thanks.
Is your primary monitor on the right and your colleague's primary monitor on the left? If so, dragging to your second monitor on the left would put the form in negative X coordinates in the virtual screen and could be the cause of the issue. Even if this isn't the case, I would recommend reporting the issue to the support group: http://ko.infragistics.com/gethelp.
Huh.. weird.. I just checked on a colleagues machine and there the problem doesn't exist!? When he drags the form across his monitors, the tooltip always appears as it should.
Strange eh?
