285
UltragridExcelExporter - The indent level must be between 0 and 15.
I am using the excel exporter to export a grid to an existing workbook/worksheet.  I only have a single band but the export crashes with the error below.
I am using Exporter V2.0 with VS 2005 / Excel 2003.
Note that the export works if I create a new XLS when exporting rather than use an existing worksheet.
 Dim Workbook As Infragistics.Excel.Workbook = Workbook.Load(Filename)
UltraGridExcelExporter1.Export(ugFundProcessing, Workbook)
I have tried playing with the indent level but no joy. I only have a single band anyway.
Is there anything else I can try?
regards
Darren
{"The indent level must be between 0 and 15.
Parameter name: value
Actual value was -1."}
   at Infragistics.Excel.WorksheetCellFormatData.set_Indent(Int32 value)
   at Infragistics.Excel.WorksheetCellFormatProxy.set_Indent(Int32 value)
   at Infragistics.Excel.WorksheetCellFormatProxy.SetValue(CellFormatValue valueToSet, Object value)
   at Infragistics.Excel.Utilities.CopyCellFormatValue(WorksheetCellFormatProxy sourceCellFormat, WorksheetCellFormatProxy targetCellFormat, CellFormatValue value)
   at Infragistics.Excel.WorksheetMergedCellsRegion.Infragistics.Excel.IWorksheetCellFormatProxyOwner.OnCellFormatValueChanged(CellFormatValue value)
   at Infragistics.Excel.WorksheetCellFormatProxy.OnPropertyChanged(CellFormatValue value)
   at Infragistics.Excel.WorksheetCellFormatProxy.SetFormatting(IWorksheetCellFormat source)
   at Infragistics.Excel.WorksheetMergedCellsRegion..ctor(Worksheet worksheet, Int32 firstRow, Int32 firstColumn, Int32 lastRow, Int32 lastColumn)
   at Infragistics.Excel.WorksheetMergedCellsRegionCollection.Add(Int32 firstRow, Int32 firstColumn, Int32 lastRow, Int32 lastColumn)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.ExportBandHeaderRow(UltraGridExporterHelper exportHelper, UltraGridRow row, UltraGridBand band)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.ProcessHeaderRows(UltraGridExporterHelper exportHelper, UltraGridRow row, UltraGridBand band)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.ProcessGridRowInternal(UltraGridExporterHelper exportHelper, UltraGridRow row, ProcessRowParams processRowParams)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExporterHelper.ProcessRow(UltraGridRow row, ProcessRowParams processRowParams)
   at Infragistics.Win.UltraWinGrid.RowsCollection.InternalTraverseRowsHelper(IUltraGridExporter exporter)
   at Infragistics.Win.UltraWinGrid.UltraGrid.Export(IUltraGridExporter exporter)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, Worksheet worksheet, Int32 startRow, Int32 startColumn)
   at Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter.Export(UltraGrid grid, Worksheet worksheet)
   at IAIFormulaEngine.ReportingMethodMaint.GenerateTemplate()
   at IAIFormulaEngine.ReportingMethodMaint.ToolbarMain_ToolClick(Object sender, ToolClickEventArgs e)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnToolClick(ToolClickEventArgs e)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.FireEvent(ToolbarEventIds id, EventArgs e)
   at Infragistics.Win.UltraWinToolbars.ToolBase.OnToolClick()
   at Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.DoClickProcessing(MouseEventArgs e)
   at Infragistics.Win.UltraWinToolbars.ButtonToolUIElement.OnMouseUp(MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraControlBase.OnMouseUp(MouseEventArgs e)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
