335
persisted data to the gantt is incorrect
the ganttchart display deserialized data the wrong way. As you can see below task B & C are subtask of task A. The displayed data is the deserialized one. so before i serialized the data and saved to file i defined that task C is successor of task B. I should look like A1 and B1 are displayed. I hope it is no bug, that subtask aren´t properly handled. Has anyone an idea during my investigation, all my work stops at the unlove AllProperties member which contains the relevant propertievalues in a base64 encode string.... any idea? NA 10.2
Image shows the wrog behavior. task C should be after task B like the relation between A1 and B1.
