250
Saving Resources in UltraGanttView
This is my first project using the UltraGanttView so I'm still learning.
I've got my database tables for Projects and Tasks set up.  Not sure I have the field values accurate.  I saw in the help where it lists the fields but not types or sizes.
When I use the DataBinding sample and display tasks, it shows fine.  I can modify the tasks and then save back to this table and it so far it seems to save all fields except the Resources.  The resource will display on screen, then I save.  If i restart the project the resource is not there now where all other changed properties are.  I can't view the values in AllProperties in sql since it is binary.
Should the AllProperties field be a different type or be larger?  Also, am I supposed to be populating the Resources box in some way for it to match up?  If so, how to I load the possible Resources?
Thanks for any help.
