500
WinGrid - Load/Save layout
Hello
I got some questions to Load and Save WinGrid layouts, the behavior on getting over 50thousand lines of designer code when adding a bindingsource. The bindingsource look on a datasource table which has an 'inherited' parent/children relation on itself.
My first problem is the datatable in my datasource which has a recursiv character / parent/child relation. The designer file sometimes takes few minutes to load and has over 50.000 lines of code an nearly a thousand band inherited. I tried the property singleband and maxbanddepth to 1. But i am not shure if this was going to help or the fact that i deleted the table relation on itself in the dataset.
My second problem is about loading the display layout. I wanted to load the layout from a database depending which user is 'logged in'. For this behavior i got a usercontrol with a wingrid. The first 'standard' design comes from a lyt-file when no layout (or standard-layout)  could be found in the database. But sometimes columns which i made hidden are visible again and i don't know why.
Third problem is that after some changes the event 'AfterRowLayoutItemResized' didn't fire when i changed the size of a column-width or row-height. I wondered why know cause earlier it fires at this point. I tryed to delete the event and add it again but it still didn't work
And now a forth problem is that i could save the layout, but the layout won't load correctly. The column-width changes load correctly. But the Row-height changes won't load.
Thanks for your support.
Greetings from germany
Dietrich
Sample Code:
UserControl
private string user = GridExtensionClass.STANDARD_USER;
        public string User // this i how the usercontrol gets the userchange from the parent frame
            get { return user; }
            set
                user = value;
                GridExtensionClass.loadLayout(ultraGridWorkgroups, ecU_UserLayoutsTableAdapter1, user);
                ultraGridWorkgroups.Refresh();
private void ultraGridWorkgroups_AfterRowResize(object sender, Infragistics.Win.UltraWinGrid.RowEventArgs e)
            GridExtensionClass.saveLayout(ultraGridWorkgroups, ecU_UserLayoutsTableAdapter1, user);
        private void ultraGridWorkgroups_AfterColPosChanged(object sender, Infragistics.Win.UltraWinGrid.AfterColPosChangedEventArgs e)
        private void ultraGridWorkgroups_AfterRowLayoutItemResized(object sender, Infragistics.Win.UltraWinGrid.AfterRowLayoutItemResizedEventArgs e) //doesn't work anymore, event won't fire on row size/header changes
HelperFile:
public static void loadLayout(UltraGrid grid,
            ECU_UserLayoutsTableAdapter tableAdapter, string actualUser)
            byte[] myData = (byte[])tableAdapter.ecu_loadLayout(actualUser, grid.Name);
            try
                //grid.ResetLayouts(); //no changes on the row heights issue
                //grid.ResetDisplayLayout(); //no changes on the row heights issue
                grid.DisplayLayout.Load(new MemoryStream(myData));
            catch (ArgumentNullException ane) //if no layout is found in the database
                loadRessourcesLayout(grid,tableAdapter);
                //GridExtensionClass.saveLayout(grid, tableAdapter, "Standard");
Parents Reply Children
No Data
